I recently bought a 96 Ranger from the original owner. It has 107,000 miles. When I got the truck it would never get up to temperature. I replaced the thermostat with a CST brand stat from Autozone. Then the thing would get to the normal temp, but the gauge would always sweep up to the half way point then come back down to normal temp. I would check the coolant every morning, but it was never low - so there wasn't air in the system. Then I decided to pull the stat back out and look at it. The spring had rotated in a manner that it was causing it to open crooked. So the brass part was rubbing on the housing on it's way open.
I actually put a Fail-Safe thermostat in there now made by motor-rad; also from Autozone. It works beautifully now. I also followed some advice I saw elsewhere on TRS to cut the little pellet out of the thermostat, which made it a lot easier to burp.
I just thought that may be useful info for someone that had the same problem.
