Fix for droopy sun visor?
groovtubin
5+ Year Member
NC
2.9 V6
Cant find anything on youtube, anyone have a slick fix for the dreaded droopy sun visor? Thanx in advance!
ok found this hths someone else!
OK, im thinking a std C clip could be inserted at bottom of spring washer......gonna give it a try, that would bolster it correctly, course getting in on mit be a pita, i mit need to buy a dozen..lololol
For the washer, you can use a bronze washer, available at marine stores. You can buy a bag of various springs from Home Depot. You can put a tube of shrink wrap over the arm that goes into the visor. I bolted mine to my roof with 1/4" bolts and nyl-nuts. Prevents the dumb criminals from using your visor to pry out your radio and such.
Cant thank you enough for sharing your information, God bless n hope u have a awsm Labor Day! Was stationed in ATlanta 91-95 Lived in Marietta .........2665 favor Rd Apt 2F-9! Had my first n only child there, i knew EVERYONE in Windy Hill music district best time ever there! :) Wife worked at Uncle Buds Catfish..
You can see what the guy in the video is doing by taking your visor, push up on the very end to support it, and pull down on the visor with the other hand at the pivot point. It will straighten right up for a second or two. Like he said, the center hole in the 3 hole casting is worn out. This is letting the spring pull the 90 degree portion of the arm too far up into the casting, which then lets it sag. That washer he added stops the spring from pulling the arm up too far.
I have been wondering how to fix this myself. If you use his method, I would make a easy way to get the spring off again, I suspect over time his washer is going to wear out and need replacement again. Once it wears enough to make it's way around the 90 in the arm, you are back to square one again.
I had thought about using one of these split collars. You would not have to take anything apart, and it's much thicker than the washer so i don't think it would ever wear enough to make it around the 90. I don't know, I hope it's not too thick to fit.
I just switched took the off and switched sides.
Duct tape, and/or safety wire. Possibly some superglue and a zip tie as well.
Moved to Atlanta in 2002 because of 9/11. We had two children born in Georgia, the rest are all Yanks :-D
