Fitting stuck on internal slave cylinder
It might. That's what I would probably try. Just be careful.
Yes, a small 1/8 or so left handed bit would pull that bad boy right out. Also, try to heat the surrounding metal with a propane torch. It will expand the metal ever so slightly and aid in the removal. Work slowly, as the last thing you want is a broken bit head stuck in there.
Okay, so today I went up to AutoZone and bought a set of left handed drill bit sorta things. I got home to find out that they had a square end, which all I have now is a little low power hand held one. (quite ironic that we needed a drill for something else today and ordered one). So I guess I'll just use them on the new drill. But the smaller the size drill bit, the smaller the square on the bottom of the bit. How will I be able to put this in? Will I need to buy a new adapter for it?
