Fitting 33's on 1994 explorer
99offroad
Current setup, 2.5 James Duff with extended radius arms with hemi joints n front , 1/4" spacer, rear is add a leaf with extended shackles. I'm currently running 265/75/16 (32")
Any Ideas on fitting 33's?
THANKS!
Put some 4" coils in front and SPOA the rear end
265/75's are lust a little over 31" with a load(on the vehicle), at least that's what my old 265's measured out to. 285/75's are what I have on my ranger now with only a little over 2" in t-bar crank and they fit fine. Less Schwab said they are 33.8" but on my rig they are about 32.2". It doesn't look funny at all. Most of all, no rubb! How do your 265's fit? You may be really close.
no way the 285 's will fit, well only if I was planning on no offroading.
SPOA=Spring Over Axle?
Myself, I did a 6" on mine. Fits 33" tires with no issues.
If you look close, the only area where I had an issue was the running board @ the front of the fender. If you don't have running boards, no problems.
