Fit for 2002 Edge
Ger42
Plantation FL
This is what I'm looking at Hankook ventus St RH06 275/60R17 tires on a 17 X 9 wheel for my 2002 Edge. Will it fit? Site I'm looking at says it fits a 4WD. Same setup as my Edge 2WD????
Thanks
Gerry
Email from vendor says no guarantee fit only for 255/50/17
Here is calculation comparing stock (235/75/15) to what I want
Current Tire New Tire Difference
Diameter inches (mm) 28.88 (733.5) 29.99 (761.8) 1.11 (28.3) 3.8%
Width inches (mm) 9.25 (235) 10.83 (275) 1.58 (40) 17.1%
Circumference inches (mm) 90.72 (2304.36) 94.22 (2393.27) 3.5 (88.91) 3.9%
Sidewall Height inches (mm) 6.94 (176.25) 6.5 (165) -0.44 (-11.25) -6.3%
Revolutions per mile (km) 698.39 (433.7) 672.45 (417.59) -25.94 (-16.11) -3.7%
I se 1+' taller and little over 1 1/2" wider.
Am I wrong?
i have 17x9 w/24+ offset and 275/60/17s on the front of my truck(03 ranger 4x4 xlt)...it rubed on hard turns until i added a 1/4" wheel spacer(no biggie). The should fit in the rear just fine, but you might want to run a spacer just soo they front and the rear are the same width.
Did you use longer lug nuts?
Gerry
