- Jan 13, 2019
- Pennsylvania
- 3.0 V6
- Automatic
- My credo
- My world is filled with stuff that needs to be fixed
Obviously if there is a large disparity in mass you'd want to be in the larger vehicle, as you'll be using the smaller vehicle as crush zone, and that reduces your rate of deceleration. If there is any kind of parity in masses then you sure don't want a rigid chassis, as then the deceleration rate will be massive and your body will be more damaged by that.
So yeah, you can drive around some large old rigid chassis vehicle, hoping you don't hit anything else that is of similar construction.
Back on this topic, my Ranger has a full frame, and it weighs about 3100lbs - probably not a lot different than this thing. I suspect the cargo and towing capability for a truck in the class could be made similar regardless of unibody or full frame construction. If you want a strong structure you'd use a space frame over some flat ladder frame every time, it wouldn't even be a contest.
