Bronco648
- May 23, 2019
- 2.3 (4 Cylinder)
- Automatic
- Tire Size
- 15"
I am in the process of re-assembling an '85 RCLB with the 2.8 V6, A4LD & RWD. Over the weekend, I had the driver's side of the TTB out and figured I'd replace the driver's side motor mount. I was confronted with this:
According to every source I can find, the after-market motor mount (EM-2940) is the correct unit for the (early) 2.8 V6 Ranger. However, it appears as if I have the wrong part. The locating pin (yellow arrows) is 180* from where it's supposed to be and the threaded stud is slightly higher on the after-market part (which means the motor mount will sit slightly lower). It's almost as if the side of the motor mount that attaches to the frame was molded in upside down (yet images on the web show this layout to be correct for this part number).
Has anyone encountered this before? Is there any chance that a different motor mount has the correct orientation (like one from a 4X4)? The motor mounts were purchased by the PO.
Re-using the original mount is not an option because of degradation (due to oil). The vulcanized rubber is like Jell-O in some places.
Any insight/help is appreciated.
TIA, Dave.
TIA, Dave.
