meatshieldchris
- Sep 29, 2009
I've got some growling happening in a new-to-me '92 4x4, coming away from a stop. I initially thought it was clutch chatter, but I quickly realized I could make it happen with the clutch fully engaged, simply by being rolling, clutch fully engaged, rpm at about 1500, then just giving it some gas. I can't make it happen by doing the same in 4rth or 5th at low speed, so I don't think the clutch is slipping. I can put it into 5th at about 30km/h, hammer on the gas, and the rpm doesn't increase like a slipping clutch would, and it doesn't sound anything different than just lugging it in the wrong gear (I can't really hear the growl, but maybe the lugging is masking it). Also, I can make the noise lessen over about 2000 rpm and dissapear completely over 2500 rpm.
The more I drive it, the more I think it's limited to just first gear. After a long highway trip, there's a slight knocking or ticking sound. It seems to quieten down and fade away if I hold the clutch pedal in. Release bearing noise? Could this be causing clutch chatter? Could glazing due to chatter cause continuing chatter even with the pedal fully out? Or do you think this is a first gear transmission problem since I can't duplicate it in other gears?
Any other tests I can do to narrow it down?
