firestone mt's vs pro comp at's
gettle03FX4LevelII
Harrisburg PA
any one know if fierstone MT's are wider and or taller then a pro come at. i currently have the 33x12.50 on 15x10's that came with the rims i just bought on sat. i can get some firestone MT's real cheap. the pro comps rub on my lower valance and i had to take the fender flares off. i know the mt's will have a bigger thread but i dont know how they compare to height and width to a pro comp AT. any input would be appreciated. thanks
You should be able to look up exact specs at each manufacture's website.
A 33x12.50 no matter the brand is always close to being 33x12.50. If your tires rub, you need to trim, lift, or run smaller tires.
Where are the rubbing?
they are rubbing on the lower valance. pretty much just at full lock. its probably because they rims are 15x10 but i got a great deal on them. might try trimming or i just may wait and save for a body lift. I know i heard people say thet BFG AT's tend to run narrow i was just not sure about any other brands
Trim or remove your valance. BFG also come in a 33x10.50x15" size.
Unless you have a suspension or body lift, a 33x12.50 is going to rub no matter what.
