wtn4x4
I am fed up with stiff suspension!
I have a 94 regular cab 4x4 w/ 4cyl 5spd and no extra weight to speak of. Then add a james duff extended radius arm lift kit with 6" skyjacker coils dual front shocks and skyjacker leafs in the rear makes for one bumpy ride. The blocks have been removed and rustys extended shackles have been put on.
I would like to get more out of my truck because I barely flex my suspension when I jump the damn thing. Every imperfection in the road is felt in my spine. What is a good way to run softer dual front shocks and make the rear end suck down more instead of looking like a pogo stick with out using fox shocks or bypass?
The current setup is dual procomp es1000 and james duff rear shocks.
