- Sep 3, 2010
- Largo, Fl
- My credo
- None
Yes,its a little to close for my comfort. Although this truck will be my everyday driver travel truck.. You know I'm hunting that low 11 second time slip .. It will happen just once.then it will never see the 'track'again"
What amazed me was when I set the mock up short block down in there.. Then bolted the transsmision up.. It did not squat one bit!
I know what you mean. You will find that the engine package doesn't seem to move much even under torque. I thought that with the clearance at the pan being so tight it would at some point make contact. I check mine from time to time and have not found any evidence that it has touched. I still plan to create a little more room when the engine comes out for the first time.
