Hard to say, but you've obviously put it back together with something missing, or a gasket in the wrong way. If you have the time to be without it, I'd just say send it to me and I'll straighen it out.
Thanks for the info so far. Got a hold of manual, I will read it and try again over the weekend. Overall it seemed relitively simple and I didn't end up with any extra parts, probably a gasket issue. Maybe I didn't clean good enough, cleaned all passages and sprayed compressed air thru, twice.. Wasn't too dirty to begin with, but there was some sediment in the bowls, and the last power valve appears to be from '00.
I matched up the base gasket with what I could against the original one (came off in pieces), but there's the chance that it might not be the right one - would this cause an issue like what I've described? Been trying to get a hold of a good working carb to make sure it's not something with my engine since it's been setting since Nov., but still nothing has changed.
If I still can't get it, I might take you up on that offer. Debating buying a new one tho, can't wait to finally drive this thing again.
