make sure you have plenty of fuel to go with that nitrous and you should be ok. In fact I would run it a little on the rich side to be safe (get an air fuel ratio meter). this of course assumes your engine is in excellent condition. if you have worn rings or anthing of that nature the increased cylinder pressure and temperature will severley increase the rate at wich your engine degrades. you may also want to consider getting a cooler thermostat. you want to try to avoid overheating your piston rings. Bottom line: do some research an make sure you tune your nitrous correctly.
Also the 2.9 valve train doesn't seem to be particularly robust so wtch those high RPM's.
I'm no stranger to nitrous. I appreciate the advice though.
