- Aug 26, 2008
- Automatic
- My credo
- Failing is easy. Everyone can do it.
Hiya,
Just a quick one. Picked up a used clutch master and hose from the yard on Saturday and did the install yesterday. Took about 30 minutes to bleed out the air, but finally had a rock hard pedal with it going against the check valve in the fitting. The old one had a tiny bit of 'sponge' to it. Not a lot, but just a hair of an air bubble it would seem.
At any rate. The used one came out of a ranger with a 4 cyc. It does not have the insulation sleeve around the line near the fitting to the slave. I attempted to remove the one from the Explorer, and no dice.
Is this really needed? The test drive yesterday seemed somewhat promising, as it was still 'clunky' but seemed to go into 1st somewhat better then before. Reverse gear? I have to let it sit with the clutch in for several seconds before backing up. It's like the input shaft is still slightly spinning for a few seconds before it goes to a stop and I can get it into reverse without the gear grind.
The big test will be the extended drive later in the week, but the lack of that insulator is concerning me. I can probably come up with a section of water pipe insulation and wrap it up with the silver foil tape. (The same stuff we used to use to keep our sink from freezing)
And yeah...I"d love to meet the person that came up with the idea of the plastic clip and steel fingers to retain the line...and kick them in the bawhoogees. What a huge PITA!
So just need to know about that insulator. As for the clunky shifting? I'll be pulling the spring washer(s) from the shifter once it gets cooler outside. I believe part of the issue is the clamping action of the ball shift thing and the spring washers is to tight. This might be a case where a tad more slop is needed. (Typical Dorman Junk!.)
Thanks!
S-
Thanks!
S-
