VaGent
OK guys I need some help. I took the TB & IAC on my 2.9 & cleaned it really good. I installed new gaskets when I put them back. The engine runs 100% better then it did BUT, I cannot figure out why it won't idle below 1200 RPMS after cleaning these items. I've checked every hose I can find that is a vaccum hose, checked the timing, made sure the STOP screw on the throttle body was not turned in too far, rechecked the TPS have done everything I know to do. It was idleing at 850-900 BEFORE I cleaned the TB& IAC valve & that is all I did to the engine other then check out the vlave cover gaskets. I'm at wit's end trying to figure this one out. I even checked the timing & it was set @ 10 degrees just like the book called for. Anyone got any ideas what the problem could be? I'd sure appreciate some help on this.
