12 Idle Speed Control motor not controlling idle properly
53 Throttle Position sensor too high - TPS
64 Intake Air Temperature (IAT) signal low or grounded.
64 first, get a volt meter and a couple of sewing pins and test the sensor.
Sew pins are to pierce the wires to test voltage live.
My bet is a wire is shorted.
Read here for voltage you should expect:
http://oldfuelinjection.com/index.php?p=29
sensor is called IAT or ACT
Basically the computer sends this sensor 5 volts, as the temperature of this sensor goes up the voltage goes down.
TPS can be tested the same way, the 53 code.
Computer sends this sensor 5 volts, when throttle plate is closed computer should get .9 volts back, when throttle plate is wide open, computer should get 4.9volts back.
So as the throttle plate opens voltage should steadily increase from 1 volt to 5 volts.
12, IAC valve, remove connector and test ohms, should get 7-13 ohms, because there is a diode inside if you don't get a reading reverse red and black probes as the ohm test will only work in one direction.
