Fast blinking blinkers
Prostreet Ranger
Roseville, Mn
I looked and couldn't find anything on this. I did an 01-03 head and taillight conversion on a 98. Because of the extra front blinker bulb on the 98, I cut the extra socket out of the harness so the extra bulbs weren't blinking under the bumper. The blinkers, both right and left now blink fast. Hazards flash normally. I thought it might be a different flasher for the 01, but O'Reilly said its the same flasher. Anyone one have any clues without adding the extra bulbs back in?
Get an EP27 flasher relay, it's ment to be used with LED's but it should bring your blinkers back to a regular flash speed
do all the lights flash on all sides if they do i wouldn't worry about it. It doesn't really matter if they blink fast. or you could have a burnt out bulb somewhere
All the light s work. To me it just doesn't look right. The truck is too nice to have things not just right.
I'll say it again get an EP27 it'll fix your problem
Bought a new flasher today, blinkers work like they should. I can't believe I put up with that all last summer for such an easy fix. Thank's for the help.
