- Feb 24, 2008
- Age
- 44
- Automatic
In an application like a super-duty or something like that, I agree with you 100%. However, IF any of those fans listed on your chart coulc be made to fit, they would easily keep a v6 B2/Ranger as cool as the stock fan.
That being said, I've never seen the purpose of switching from the clutch fan to an electric fan, except for possible water crossing adventures or insane body lifts. At normal travel speeds, the fan does little-to-no cooling of the radiator as wind pressure from the vehicle moving is whats blowing thru the radiator to keep it cool.
The only way you'll notice any kind of power gain is if your clutch fan is froze up and is running all the time anyways. its MUCH quicker to replace the clutch than it is to remove the fan, mount up an electric, run your wires, install a temp. switch, and a bypass switch. And after all that, the electric fan is gonna put the same if not more of a load on the engine thru the alternator.
If you need one due to fitment issues, then by all means. But if you're looking to free up a few ponies, you'll soon find you're beating your head against the wall.
