Hinkanator
I could use some advice. I'm no mechanic, but I will try to be detailed.
I bought a 1989 Ford Ranger XLT, with a 2.9L V6 engine and A4LD automatic transmission four months ago from the second owner. The guy told me the AC needed a charge and the cruise control would only work every so often. The truck idled rough and chugged once it decelerated and got under 1000rpm, but I did not think it was out of the ordinary for a 26 year old truck. I changed the oil and transmission fluid and filters within the first week. After reading the issues with the A4LD, I wanted to be proactive in dealing with some of the problems, and correcting some issues. I replaced the exhaust intermediate pipe, muffler, and tail pipe, which had broken off part way and were pretty much rusted through.
My grandfather and I replaced some of the vacuum connections from the fuel injectors that were loose. We charged the AC, but could not get it to work, which we narrowed down to one of the electrical wires. The Ranger ran significantly better for two days. Less chugging, smoother shifting, and less rough idles.
Then, a couple days later, I backed out of my driveway, put it in drive and drove to the stop sign at the end of the block, and once I stopped and went to accelerate, it just revved up like it was in neutral. I ran the shifter, which is on the column, through the gears and it clicked back into drive and I had no more issues. The next night it did the same thing. Reversed, drove down the block and once I stopped and started it revved like in neutral. Shifted through the gears and it clicked back in and drove as normal. The day after that, pulled out of the parking lot at work, and it happened at several stop signs, so I got it home as fast and with as many prayers as possible.
I read about the vacuum modulator causing similar symptoms, and with us changing some of the vacuum connections I thought there maybe something there. After I had to cut off and purchase a new catalytic converter (completely terrible), I changed the vacuum modulator and put the catalytic converter on. The Ranger shifted soundly through all of the gears on the column, but would not make the transition out of first gear when in drive. It would just keep increasing the rpm and not transition through the gears. I could manually shift between the first and second gear on the column and could feel a difference between drive and overdrive, but neither would progress out of first.
I had purchased all of the items necessary to follow the valve control body rebuild diary, and decided to go ahead and do that rebuild. I followed all the instructions and found the 1-2 transition bore had the tendency to compress and stay stuck open. I cleaned it and made sure once put back together that it was smooth, and was hoping that could be where my problem was being caused.
When I got everything back together, my Ranger now will not shift into any gears at all. It will only go from park to revving up like it is in neutral. There was a slight glimmer of drive after several passes through the gears on the column, but nothing to move me up to any kind of speed or even back me out of the driveway.
I feel completely defeated. I do not want to open the pan again and waste all of the fluid after being so carefu and all of the time it took for the rebuild.
I have no ideas except for maybe the linkage cable? I guess there still could be a vacuum issue somewhere.
Anyway, I love the truck and feel like it is a very solid vehicle with lots of life left. I just can't get it figured out and my Improvements seem to be making things worse.
Any help or advise would be greatly appreciated.
