eighty6gt
- May 5, 2015
New LUK clutch, the disc cannot be installed backwards or you'd never bolt down the pressure plate.
When I installed the master couldn't orient the pushrod suitably to get it lined up with the hole in the master and clip on to the clutch. I left the master through the firewall hole, then when it came time to hook it up I opened the bleeder and pushed the master through that infernal square hole and locked it in place.
Clutch is way too high, lever up against the dashboard near the pivot.
Can't find any similar stories. I think I'm going to have to start over with new hydraulics.
Thanks for any help!
