Facing surgery / time off- or just deal with it.
I know a few people that have had failed surgeries with no fault of their own (surgeon not doing what they were supposed to, defective hardware, etc). I also know a few people who have had failed surgeries because they won’t do the therapy because “it hurts.”
The therapy after surgery hurts. I’ve been there. Grit your teeth and buck up. It’s going to hurt a lot before it feels better. After my hip surgery I pushed as hard at therapy as the therapists would let me. Hot packs before therapy and ice after. My hip isn’t as good as it was before it got injured, but I’m way better than it was right before surgery.
Well, I got the call for the orthopedic consultation, its next friday. Im pretty sure I’ll go through with it, Been doing more with my right arm trying to not use the left (if possible) Its giving me some back strain somehow, had plans of working on the tractor this weekend but think im better off resting up instead. I definitely need to take it easier. I dont bounce back like I used to.
That's one of the problems that dad encountered with some of his injuries. Trying to lessen the load on the injured part increased load on other parts and ended up damaging the good instead of helping the bad. One example is that his leg was messed up in the plane crash that started everything (Cessna 172, he was a student pilot and experienced engine failure with the instructor). Torn ligaments, severe chemical burns, etc. Well at the time he was working on cargo aircraft, and the leg injuries made it difficult to climb or stand and work for long periods. They accomidated and let him stick to jobs where could sit and scoot around. Well that lead to torn rotator cuff in his shoulder due to the additional stresses and strains from that type of moving around.
There were also some crushed bones in his ankle that he never let them fix, and that no doubt compounded the wear and tear on the other joints from favoring that ankle. He wouldn't let them fix it because fixing would mean fusing parts of the ankle and limiting motion. I wasn't experiencing his pain and discomfort, but I always wondered if allowing them to do that would have had a positive net improvement. Thinking that he would have been able to walk and move better, adjusted to the limited motion, and been much more active in the later years.
I know I wasn’t looking forward to surgery on my hip until about a week before the surgery date. At that point I was pushing hard to finish a few things up and every time I drove my F-150 (stage 2 or 3 clutch), despite it being a hydraulic clutch which helps, I was in tears from the pain to drive that thing. I was confident in the surgery though, my surgeon worked on pro athletes and after my surgery went on to full on research and teaching.
Get it fixed now, if you wait you'll be older and recover slower.
When I had surgery on my right hand I managed to shave left handed, taught myself to write left handed well enough to do Sudoku, sort of learned to brush my teeth left handed abut struggled to use toilet paper with my left hand. You'll get through it, just try to think of things you can do now to make it easier on yourself. Maybe put your right hand in your pocket and practice a little.
Good luck.
Don't really see how playing pocket pool is going to help, but to each their on.
It would force him to use his left hand. What he does with the right hand is up to him.
the “good “ thing is that the bad (or should I say “worst” ) shoulder is the left one, Im right handed. Im sure theres issues with the right shoulder too but its the left one thats in need of surgery. Yeah, certainly true that waiting will only make things worse in the long run. Maybe when I get back to work after it all I will be on a less demanding machine, I could certainly get used a slower pace. One hard part for me will be recovery & NOT doing anything. Guess I can read & draft up some future projects. Crops will be off & I can explore the fields with the gator at low speeds.
A shot wouldn't have caused all that damage.
I've had rotator cuff surgery on both shoulders (2011 and 2020) and both knees replaced (2023 and 2024).
The shoulders hurt worse and longer than the knees.
I was told that the shot may have somehow aggravated the situation. But youd think that whenever it happened there would have been severe pain, Im guessing it happened at work, the machine I run has to be partially disassembled every day at the end of shift to be cleaned out. Before it’s cleaned out the part thats removed weighs over 170 pounds, im guessing its at least 100 empty. There was no way to mechanically remove / install the blowhead from the machine when it was first put in, now I have a heavy duty pallet jack I use. Thats all I know that could of caused it. Ive ran this sand core machine for the last 4 years, the guy that ran it before I did is quite a bit bigger & apparently never bothered him.
I don't know if it will help you but I was on the book of faces a while ago and of course saw an ad for BPC157 I think it is, so looking for it I took the lazy route and ordered a cheap supplement on Amazon (they don't have BPC157 from what I found) but got a cheap peptide that sounds like it does similar by increasing the circulation in shoulders and such. I've been taking it for a week and have actually noticed a difference in my bad shoulder, wasn't expecting it really... $36 for a 3 month supply so I'm going to give it a full shot at working... if curious it's THIS. I have no stake in this, just have been suffering from reduced use of my left shoulder for like 3 years, haven't tried anything and nothing has changed until I tried this...
My left shoulder has been giving me grief for years. Not my dominant shoulder either. Severe arthritis, bursitis, torn something, and some other shit wrong I dont remember the name. No mention of surgery so far, but I'd rather have it done and over with than futzing around for years with " therapy" and cortisone shots.
Going in today for another cortisone shot...
