The_Dealer
well i decided im sick and tired of my driveshaft hitting my ra xmember and tired of the f'd up caster and bumpsteer so i hunted around the shop for some scrap metal. i found some pieces and decided to make some ra drops, they are 2" of drop. first i want to know will that be enough to run 4" springs?
next thing, did i drill the bottom holes to far forward(towards the front of the rig)? if i did will i be able to move them using the same pieces i already have? or will it be too close to the holes ive already drilled? pretty much if i redrill the bottom holes further back will it make my tires to close to the back of the fenderwell?
btw this is a rough cut bracket i just wanted to test fit them up before i put too much work into them, the other side is a complete duplicate. and the reason im asking is my passenger side shaft was hitting the bolt in my pivot bracket. another thing is the bolt was never mounted when i got my rig and the bracket kinda pulled away from the xmember, could that be why the shaft was hitting? only on the passenger side? i plan to use my c-clamp and pull it back right and drill my hole and mount it up right
