OK, this has been a project too long in the planning, though it will be easier to finish before the cab goes back on Warthog.
Original style mounts for the Ford 2.3 are garbage. Didn't even last 2 years for these replacements.
And the low tech vibe damper just wasn't cutting it... And its nice to know that the crossmember in the pic is GONE and that old Skyjacker bracket is gone too. All replaced with Tuff Country drop brackets and extended radius arms.
The plan has changed about a dozen times. But I finally figured how I'm going to do this. A mix between easy for me to do and what SHOULD hold up well. In the pic below are the parts and the rough layout. On the left is the motor side plate. The tabs will be cut down some and welded to the motor side plates. Next is the bushing which will fit in the tabs. The 2x2 tubing will be cut down to about 1.5" tall pieces and reliefs cut to fit the bushing sleeves. And those in turn will be welded to the frame side plates.
Too bad I don't have access to tools like I did at my last job. There I had metal cutting bandsaws, lathes, chopsaw, bead blast cabinet, paint booth, hydraulic press. And there was a complete machine shop I could use from time to time.
I know at least one person really interested in me getting this done soon. Can't believe I bought those bushings and tabs 11 months ago from http://www.suicidedoors.com.
Soon as I get this projects done, I should be able to get the cab back on the frame...
