huntin_muddin_91
V8 swap under way and i am on budget... not tight but wanna keep it tight as i can of course. So i got 4wd and long ago scored a deal on craigs list w/ compleate 2wd conversion. so im using my 2wheel frame pads i got a book from advance adaptors w part numbers and pics, long story short guy at parts house got me a set of 88 f150 mounts look exactly like what is pictured. got the engine in for a dry fit n lookin good to me, now any one ever use these before i run into a issue later on in the build off the bat think my air cleaner might be a bit big as far as the fire wall but i already moved the bottom w/ a small sledge, my valve covers were touching a lil not sure if the mounts were at fault for that but problem solved for that. Thanks for reading!
