f150 coils and for the rear?
jarfly
I have read some were f150 coils will give some lift but what all do I need? I can make a lot of stuff as in this is goin on the truck my welding class is goin to be buliding. Also what is a cheap way of liftin the back end.
differnt leaves? Also this stuff will probley be junkyard stuff so what kinda leafs will work?
4 door Explorer leaves should get you around 1.5-2". Belltech 6400 shackles will also get you the same.
I thought I read somewhere that exploder leaves will work from a 4 door for 1 1/2 lift
I need 3 inches at lest wanna put 33's.. What is the cheapest way of doin this? I wont hav to much to spend
junkyard leaves + the belltechs ?
Well since its for welding class, welding and fabing are hand and hand. Make some extended shackles and drop the leaf spring mounting points to gain a net 3”.
