Josh1891
My 2006 Ford F-150 just stalled and wouldn’t start on me. I checked to see if I could hear the pump when turned on and there was nothing. Did some research read about the fpdm going bad so that was cheaper and easier so replaced that. There was no change. So I figured it had to be the pump. Dropped the tank pulled pump out of tank hooked new pump to wire harness and nothing. Checked fuse and it was blown. Did more research put power to the old pump straight from the battery and the pump kicked on. Hook old pump up to harness and the fuse dose not blow.
I am completely lost here idk which way to go next. Could the PCM or the PCM RELAY be bad causing this ? Idk any help would very appreciated right now
