was curious about some opinions, what size tire could i run with this setup and is it alignable(assume it is based of the tech article)
says f-150 coils gave 3.75" of lift in the front
and the explorer give about 2" and then a ranger lift block for the rest all attainable from the junkyard.
that with a 3"inch body lift and 289 v8(added wieght)
how big of tires could i run, and how would this setup be off-road.
thinking of setting my bronco II up like this tell i get some money back to properly do a SAS and wanted some opinions on this setup. could be done pretty cheap.
mods if you want you can move to suspension section
