??????f-150 coils??????
red rocket
U.S. Military - Active
state college PA
been lookin at the f-150 coils on a stock suspension set up and that bronco, was wondering if anyone out there has done it and can get it going down the road straight. i want to lift my truck up some more but just dropped some money in the v8 swap so the wife says no lift kit. so if anyone out there has done it and still uses it for a daily driver let me know and if you could show some pics
pm r1hatman. and theres a link in the tech library. your truck will ride like a dump truck just a fyi
All you need to do is get the bottom buckets for the F150...I think they're like $10 each from ford. If you wanna, I have a set of coils I'll give you if you wanna drive down to Williamsport Pa, they're already cleaned up and painted blue...I went a different route and decided not to use them. PM me if you're interested.
BTW, I Lol'd at your username...I guess you havent seen the South Park episode...
ext cab should weigh about the same in the front as a V8 BII so here is the one i did. bastard pack in the rear+factory block. it rides ok nothing like a dump truck had to remove the sway bar on this one and doing that helped the ride quality.
http://www.youtube.com/watch?v=SGXw3vTWhJ0
http://www.youtube.com/watch?v=atPMhx1OY3k
couple of hose clamps for the top bucket and it has not moved for 3 months or so of some pretty nasty trails and doing dumb stuff as those pics show. those are 33x12.50s on the stocker rims. rubs a little in the front at full flex but not to bad.
yea i got a 89 did the v8 swap and wanted to do the f-150 coils cause it was cheap and looked pretty easy, didnt know if it would mess with the whole alignment
it messed with the camber on the one i did fixed the camber on it and it drives fine still a little off but not bad. shouldn't mess with alignment to bad.
gonna have to try that, hopefully brinker88 can give me a hand and get those coils off of him
^ yea just depends on what bushings you already have in there.
yea i suck when it comes to alighnment guess give it a try and see where it gets me
I work at an alignment shop, I'll help you out dude
