Extended Brake Lines
Beef52751
Eastern Iowa
I need to get extended brake lines for the front of my ranger. None of my local parts store have the brake lines in the chart in the tech library. so has anyone used this from the tech library
Submitted by Bob:
These hoses are 26" long:
Raybestos: BH 38622, BH 38623
There are 2 numbers because there is a right and left side
These cross as an availble brake line for a 95 chevy k2500, so does anyone know the stock length hose so i compare???
Thanks
Din't know the exact length of the old ones but the difference is quite signifigant (in the 8-10 inch difference range). You're going to have to grind on the caliper mounting end of the chevy lines to get them to fit right but it will not harm the integrity of the sealing surface
