exploror leaves help needed now
Ranger#1
lake havasu
so i recently picked up some exploror leafs that will give me almost 2in o lift but my consern is what will the ride be like in the dez should i keep my ranger leafs and blocks of get rid of the blocks and go with the exploror leafs or mix the 2 in one custom pack hellp please advise needed:bawling:
but could i get some kind of pegressive effect by inter weaving the 2 packs buy foing thinest [softest] to thickest [hardest]
If you just want to remove the block. Use the ranger main and cut the eyes off the explorer main and pack those under the ranger main. Trimming and grinding the leaves for smooth cuts you can make a pack that rides pretty decent.
Or
I used a main leaf and load leaf from a dodge durango pack i got from the junkyard. i weaved in some leaves from a BII pack to make a 6 leaf pack. I clamped it in front of the axle and am using a spring guide in the back to keep the leaves from shimmying side to side without sacrificing droop travel, the closer center clears the gas tank but allows more travel with the stock slip yoke and helps with my pinion angle a bit.
the pack tends to like to stay arund 12-13 net travel which is about all I could hope to get with the length of the main leaf. it handles well, and rides super well. valving the rear shocs to work with the pack better has made a missive difference as well as adding weight behind the axle.
well could i cut leafs and make them go from thick to thin
