Explorer V8 engine replacement question
fastpakr
Forum Staff Member
TRS Event Staff
Roanoke, VA
Does anybody know much about the difference between the 2V 4.6 in the '95 Crown Vic and the '02 Explorer? Found one here:
http://roanoke.craigslist.org/cto/1611205943.html
Not at all worried about power, just want to make sure it's easy enough to switch accessories and such back and forth so I can just bolt in the Vic engine.
Base engine I think is the same. Intakes are different, but if you strip the 95 down to a long block and swap everything over and I think you are good to go.
