- Aug 8, 2007
- Age
- 37
- Battle Ground WA
- Manual
Well, you can use the sploder t-case and driveshaft if your truck has an A4LD auto, if it's a manual it will be an FM145 (assuming it's stock), the FM145 is shorter than the sploder tranny so the driveshaft length will be wrong too and the sploder t-case is 95% sure to be an electric POS. Around here it's $75 to have a shaft shortened.
