1991 Ford Explorer, Automatic hubs don't work. Manual change kits with hubs are little spendy. Somebody know which make and year hubs can be used from junk yard, and witch conversion to kit to buy?
Thank You
Thank You
x2 or you could hop on the band wagon and sas ur x and drive flange your hubs so that eliminate your probblemo
you don't need the conversion kit.
Tech Library, click here
about 2/3 the way down the page in the middle
Yes the 91 explorer has a 35. this link should explain the jeep hub comment http://www.therangerstation.com/Magazine/May04/offroad.htm
The kit that is referred to relates to the wheel bearing locknuts as the auto hubs use a different arrangement that is incompatable with the manual hubs. there is a part number somewhere on the site that gets the locknut set for a much cheaper price than if you buy tham as a conversion kit.
Hope that clarifies things a little.
There is no year and model for the jeep hubs. they are part of an aftermarket conversion for the jeep rear axles so that people can flat tow them behind their winterbagels.
