- May 18, 2008
- 92 & 83 project
- Automatic
Found this for sale close to me.
Ford 8.8 out of a 97’ explorer with disc brakes 3.73 with locker, 31 spline, came from a running truck
decided to use a different axle
$450 firm
Thinking about using this rear end on my 351C build.
questions -
1. will the 3inch wider have any real bearing on the differences going into a 1992 ranger?
(mounting brackets and wheel off set, street tires)
Explorer rear axle 59.5"
'83-'92 Ranger rear axle = 56.5" (7.5 & 8.8)
2. Is this swap worth the hassle and give better rear braking? now is the time for me to go it as the truck is stripped to the frame.
3. would you buy this and do the swap on your truck?
cheers thanks
$450 firm
questions -
cheers thanks
