explorer 5.0 in a '89 Bronco II
JOSEPH169
Marysville, Wa
I can seem to find anyone that has done an explorer 5.0 swap into a Bronco II. Seen older 5.0 swaps. Has anybody done it or know a link of one been done?
Joseph,
No one has replied so I'll take a stab at it. I'm in in the middle of dropping a 2000 Explorer 5.0 into a 1988 2WD BII. I've spent months collecting parts and planning the swap but just yanked the 2.9 and trans out of the BII yesterday.
I've had to convert the 2000 motor to a 1996 motor using the wiring loom and ECU from the 1996 so it has VSS and is pre-PATS. I also traded the 2000 4R70 trans out of the AWD Explorer donor for a 1996 2WD 4R70 out of a F-150 (I think).
I ended up changing every sensor on the motor including the CPS sensor and synchronizer. I'm am using L & L motor mounts (pricey but quality) and I will have to modify the trans crossmember to support the tailshaft housing. The donor came with the GT-40P heads and cast manifolds so I'm reusing those. I'll also end up shortening the Explorer's rear drive shaft and I've already ordered an extended 28-spline slip yoke, u-joint and 4 bolt flange so it'll hook up to the new trans.
I plan to wire an OBD-2 port into the loom but haven't gotten quite that far... yet.
I don't have links but there is a thread in the forum with lots of great advice on where to start with this particular job from various members like RangerSVT and MAC.
A quick search for '1988 BII' and '2000 explorer' will yield resutls I'm sure.
Good luck,
Dave
I am certainly not an expert on this--I think the main problem is the PATS and the OBD2. That's why most folks with earlier RBVs choose to use the OBD I EFI system or a carb. It makes the conversion less complicated and there is no appreciable performance loss.
You are completely correct on the PATS assessment. If I had known about PATS 6 months ago I would've looked for a donor per-1998 for sure but I had money sunk into a very low mile 5.0...
