- Aug 19, 2007
- Age
- 37
- Everett, WA
- Automatic
Its common to have issues bleeding the clutch. It may still have air in the lines. If this is the case, you need to unbolt the master from the firewall and set in on its side or upside down. This lets the trapped air escape. I did with 2 people, 1 pushing the plunger on the master up and down as if pumping the pedal, he was also gently tapping it to free any air. The other person does the typical bleeding procedure opening and closing the nipple. Good luck.
