koldcustoms
- Jan 6, 2009
'87 Supercab 4x4, 2.9L. Motor is original to the chassis except for the heads, (Ford improved design- OEM replacements).
Two questions:
1) The EGR valve has a short tube (vent?) protruding from its' body, above where the exhaust gas pipe taps in. Is it supposed to be capped, or should it be plumbed into the vacuum system? Should it be left open? It doesn't appear on the vacuum schematic.
2) The OEM exhaust looks as if it has two catalectic converters; one after the other. Is this the case, or am I looking at a Y-pipe with a heat shield and then the cat?
Thanks
Two questions:
Thanks
