Exhaust recommendations needed
bmacsys
Branford, CT
Hi, my son has a 2003 4x4 Ranger extended cab with those mini seats and 6 foot bed. It has a 4.0 in it. I would like to buy him a Flowmaster type catback exhaust kit for him to put on it as a surprise birthday gift. I bought a whole catback setup for my 1993 a few years back but I don't see any applications for this truck. Should I buy the muffler and just get the pipes from an auto parts store? If so can anybody tell me what I need to get? Like clamps, diameter pipes etc...? I rather buy him a whole kit if Flowmaster or the equivalent parts are made by any other manufacturer. Thanks a bundle.
truthfully, theres really no reason to replace the tailpipe after the muffler unless its rusted through. the sound from aftermarket exhaust systems comes from the muffler, not that pipe. i would just get him a muffler and clamp it in place of the factory one. if he wants a shiney exhaust tip, you can get ones that clamp onto the factory tip.
if you want a tailpipe too, i dont think flowmaster makes one for that year ranger, but i know gibson has several options (including split dual exhaust), and magnaflow also has a few choices.
I disagree WS, while the overall sound comes from the muffler, the pipe effects how deep it is, I much prefer the sound of 2 1/2" over the stock 2". Had a coworker get a flowmaster put on her 02 4.0 ranger with all stock pipe and it sounded like ass to me, same as my buddies b2 with the same exact exhaust as me except in 2". Get an exhaust shop to make a tailpipe, should cost $30-40.
All the pipes are looking like they need replacing too.
I have found if you do some shoping around at the mom and pop exaust shops you can beat the "cat back" kit prices.
k well auto zone sells secions of bent tubing and secions of stright get a hold of the muffler you got and sence all the bends are slip on mock it up any way you like then tack it together then remove it and lay a bead :icon_welder: i did ny full exaust in steele 2 and a quter inck foe less than 30 just the steel ill try to get some pix for ya asap:drool: if you were closer id help
i HIGHLY reccomend against going this route. my first exhaust setup used pre-bent peices of tubing from the parts store. that pre-bent stuff is LOW quality, i got about a year out of it before it rusted through and began to leak. eventually i lost an entire section of pipe while driving home from work one day.
i learned my lesson about thin-walled, steel pipe. go thick wall aluminized and save yourself from having to fight with it again in a year.
that depends on where you live here in the dez there id no such thing as rust also i had to get a pice o tube bent in a pinch so i went to a shop and got the same wall thickness but in tead o 4.70 it was 8.00 so go figure
