exhaust problem???
off_road_junkie21
waterloo ill (back home)
ok this only happens during summer. my exhaust heat cause my passanger side foulr borad to sweet so bad it has water soaking the capet. the heat sheld is still there. my wind sheld does not leak eather i cheacked that first off. my cat is hollow. what is causeing this???
Are you sure your A/C condensate drain isn't plugged?
It's not the heater core, is it?
I mean, there isn't much in that area to leak.
How the HELL can high exhaust heat make your floorboard sweat? It's a colder-than-ambient surface in near-saturated humidity that does that.
Something is dripping on it. Evap drain, heater core, or perhaps a windshield leak.
Or you drink and spill more beer in the summer.
When you disconnected your AC you didn't leave any ductwork open under the cowling?
nothing is leaking on it i cheacked for that. what do you mean by the ac duck work?? mine is all closed up! i need to get this fixed becaus it is starting to get surface rust under the carpite. help me!!!!!!!!!!!!!!!
