Exhaust Leak
Snug it up with an impact...good luck tho, those bolts tend to seize up pretty tight.
Edit: I cant bring up your pic, but I assume nothing is rusted out.
I just tried looking it up here at Carquest where I work(:D), and where the manifold comes down to the Y pipe prior to the cat, I don't carry or list a gasket. It says it is NR meaning not required. The gasket if there is one could be shot. Put some dishwashing soap like palmolive with water into a spray bottle. Spray it onto where you think the leak is. If it bubbles you found it. If not keep trying the whole exhuast or whats reachable.
There is no gasket, its a ball flange connection. Snug it up.
its rusted pretty bad. Do they sell the flange anymore? and its a big enough leak that i can feel it with my hand and hear it.
If its just the flange and not the flared pipe thats damaged, you can cut it out and get a split flange from the parts store and use it. There are a few threads here where people have used them with success.
