exhaust leak
rangerdanger9398
alden ny
i have an exhaust leak i think it sounds like a ticking right where the drivers feet are
nope, just some oil of wintergreen on the manifold nuts if the gaskets are blown, you may also check the y pipe to manifold connection as well. just idle the trk crawl under there and take your hand and feel around the connection. for the manifold get a piece of paper and put it close to the manifolds all the way around, if the paper moves from being blown you found your leak.
i had this problem is was what i call the collector plate where the y pipe hooks up to the manifold my bolts were stripped out when i put em back on and had to use some new bolts
