ranger92
I've been in the process of starting a pre runner build. its a 2wd 86 ranger. I'm using the equal length beam setup of a 69 ford f-100. I got all the old tib stuff out and started to mock up the equal length beam so I could check for clearances and start to modify any mounting brackets before i started beefing everything up and drilling holes. I ran into a problem right away though, the I beam hits the engine crossmember before it even starts to sag
see what i mean by very roughly mocking it up lol, anyway ill be dropping the beam mount down a little bit but Ill definately still be having quite a bit of contact, would I be able to just trim off the crossember lip on this side? id like to avoid having to completly remove the crossmember if i can, i dont have an engine hoist.
All in input and ideas are apreciated
I looked though all the equal length beam kits you can purchase and none of the come with a new engine crossmember and there arent many pictures that i could find anyway that show how they get around it.
