Engine wont start
jmeeks
the other day i changed the fuel filter and now the 88 B2 wont start.
I used the usual method of unplugging the inertia switch relieving the pressure all that good stuff. When I went to start the B2 after resetting the inertia switch no dice. Any advice?
went thru everything electrical still nothing :icon_confused:
Ant help would be appreciated. keep in mind it ran perfect before the fuel filter change.
Sounds like you might of put the fuel filter backwards. and if thats correct make sure your inertia switch has power coming out. mine just died one day out of the blue.
Fuel filter is in correct. The fuel pumps kick on so i took it the power supply is good.
I will double check the power out of the switch again.
Thank you for the suggestions
