Hi guys
My 1994 4x4 ranger has an electrical issue. It was running fine shut it off then it wouldnt restart. Check engine light doesnt come on. Ecm relay energizes.fuel pump relay does not have signal from ecm. Jumping relay provides fuel pressure but no injectors firing. Power verified at ecm connector. Ignition fires and will start on ether. Injectors show 5 odd positive volts at both terminals (seems strange to me) I have verified ground black wire with white stripe at ecm connector.
I am thinking Ecm, but does anyone have anything else I should check?
