jklolkik
I believe the cause is the fuel pump. I pulled it bench tested it does still work but has a high potch whine. Anyways bought a new fuel pump assembly but it is 1 inch to long and does not fit in my tank. Sadly can no longer return it because of store policy. I have a 93 ford ranger rwd extended cab with the 4.0v6.
Can anyone tell me if this is the original tank or if its a swapped tank?
