JakeBrake
- Sep 27, 2010
- Automatic
background info:
about a year ago the motor in my ranger(4.0) went bad, it has been sitting since then. i pulled the motor and transmission and just waited to come across the right motor. a few weeks ago i worked out a deal with one of my buddys and ended up getting his complete running 95 explorer with a 4.0. I pulled out his his motor and transmission, unbolted his transmission and bolted mine up to the good motor. i then began switching over the wiring harness. i switched out the sensors that didnt plug up to my harness. then i ran into trouble, the cam sensors arent the same. the one in my 97 had a longer shaft and wouldnt fit. i went to the junk yard pulled one from a 96 explorer and put that in. i put the motor in and bolted it all up and went to turn the key. it turns over but wont start. i pulled out a spark plug and im not getting any spark. and im not really sure were i should start to find the problem.
ive been searching for a couple days now and cant find any helpful information
