engine trouble
flomo600
hey i was just mudding with my buddies and then cleaned off my engine and when i got home my check engine light was on and now my engine wont start it will crank but wont turn over just keep cranking and its not te battery
no nothin looks like it got disconnected but my air filter was wet so i took it out and am drying it. And how would i fix it if i got condensation in the ditributer cap?
The 4.0L doesn't have a distributor...its got a coil pack. Check all your plug wires for water inside them and dry everything off.
Exactly how would i go about checking all of my plug wires?
i know its kinda sad but were is the coil pack?
so theres six of them right one for each spark plug and i just take them off and dry them off? and then should i put wd-40 on them or no?
so i took of each of them and cleaned them and dried them of and it stil wont start..
does it sound like it is getting gas, also you could pull the codes, there is a write up on that in the technical library to find out what is throwing the code. Also you could check the fuel pump shut off switch, make sure that didnt kick on. As for the location of that idk, i believe it is in the cab under the dash on the passenger side
