transmissions
So, I was wondering what is the best, and by best I mean a balance between work, cash, power, fuel efficiency and reliability swap to do?
I know I know, the answer is usually "whatevs you can affords/wants bro"
but i'm looking for someone to challenge me/make a case as to why what engine is better.
What we're working with:
1997 ext cab 4x4 with a 4.0 ohv
Now here's the options i've come up with.
-Sohc-I'm sure one of the cheaper and more fuel efficient answers would to be to swap for the newer sohc.
They're pretty available, have more stock power, and are more fuel efficient. Kits are available, and guides have been made on how to do it.
-302- A carbed 302 would probably be the cheapest and one of the easier swaps to make, less electrical work, and probably the most available
Downside is that it wouldnt make much more stock power than the sohc if i'm correct, and that it'd be way less fuel efficient.
Plus would be that kits are available, and engine upgrades probably have the biggest aftermarket support
The 351 would probably be harder to fit, but it has the same ups and downs as the 302 as far as I know
-Building the ohv- This I feel like would be one of the most expensive options, it'd definitely be more echonomical for dollar/hp to do a 302 swap and build that, but I dont know how supercharging or turboing it would affect it, or how much it'd cost. It seems like theres adapters for the sohc engines, and turboing that would be cheaper, but as far as it being worth the price, I doubt it because it'd have to be run at low boost and not be that powerful.
What are viable diesel options, can older rebuilt diesel turbos be used, or would they boost at too low of an rpm?
I've seen a picture of a 7.3 on here, and its dope, but it'd be retarded for me to try, and i'd like to keep the truck looking relatively stock without the cowl hood and massive stacks and having to cut firewalls etc, and it'd be a ton of money.
If i've left out any other viable options, post em up.
