PlumCrazy
OTOTM Winner
Solid Axle Swap
RBV's on Boost
2014 Truck of The Year
I have a 94 2.3, and when i coast in nuetral or push in the clutch long enough to let the rpms drop to what should be an idle it surges from like 1100 rpm to 1600 rpm until i put it back into gear and let off the clutch. It seems to get worse as the motor gets warmed up. At first it might surge 3 times then go to an idle, but as it warms up it does it longer. Never did it until it started getting cold outside, like in the 30's
I was thinking mafs, iac, or maybe a vaccum leak(but i havn't found one)
Any ideas?
Any ideas?
