jfcasey
- May 11, 2011
I've got some kind of IAC or vacuum issue I can't seem to pin point, and I'm looking to see if anyone has had the same issue and found a solution.
The trucks a 98 3.0 with a manual transmission.
When you depress the clutch to shift while rolling, the revs jump up ~500rpm. If you pop it out of gear into neutral, it does the same thing. I have shifted into neutral with and without the clutch and rolled for 3/4 of a mile and the engine stayed steady at 2500rpm.
Now it sounds like a idle problem right? Well, once I come to a stop, the engine idles fine, right around 900rpm and it drops to that idle the split second the truck stops moving.
I have replaced the tps, iac, intake manifold gasket, and cleaned the MAF. I have also driven with a cone filter and the factory air box and that didn't change a thing.
Any ideas?
Any ideas?
